apintofmild
Has anyone successfully had this to bits? If so, what am I doing wrong!?!
One of the clips on my arm rest has bust off, the one that holds the inner tray (13) to the lid (12). Looking at the exploded diagram I ***umed an easily fitted four quid part (21) would fix it. An hour of head scratching later I'm stuck!
Part 12 and the padded cover come off in one lump by removing the two pozis at the hinge (14).
Tonight I discovered the arm rest slides back and forth! Still didn't get me any nearer the missing clip though.
The padded bit is screwed on, and some of the screws are hidden inside the arm rest -so that's not the way in. I can't find a way to separate the two halves of sliding mechanism -so that's not the way in either. In spite of much (careful) prizing and writhing there doesn't appear to be any popable clips.
I'm pretty sure the way in is through the lower panel of the lid. The bit with two recessed bits (I'm guessing they're for fitting a phone kit?) doesn't seem to want to come off. Is it perhaps glued in position permanently?
The offending panel is shown uppermost shown here:
Any clues much appreciated!
