Kingy91
My car makes a noise when i set off. Not all the time but say 6/10. Its like a low pitched squeeling noise. Does anyone know anything about this? Do the 2.0 petrol engines have dmfs?
Got you I have the same on mine it's the clutch release bearing running dry.Kingy91 said:Im not sure really how to explain it. It happens in the middle of releasing the clutch though so im guessing its clutch/flywheel related. Only happens setting off never changing gear.
Was the car brought from a main dealer?Kingy91 said:I'll see where i get. I know a clutchisn't generally a warranty item but with me just getting the car I'll try my luck!
I'm sure all the accords suffer this tboDraga said:i hope i am not thread stealing and the op doesnt mind me saying this but could some one let me know if the cl9 2.4 exec accords also have the same issue i started having this issue at 95k :$ i am thinking of replacing the whole clutch
Great if they do change it and good luck.Kingy91 said:No it was bought from a local used car supermarket. They are normally very good and change anything to return tyethe car to perfect condition. If i say the release bearing is knackered they may do the clutch for me. Without a mechanic test driving it much its not exactly an easily noticeable problem. And no problem at all mate, you've asked a question relevant to the thread.
