30032977
Just a quick question, I'm having an issue with my rear windscreen washer jet? wondering if anyone has had a similar issue?
I've got nothing coming out at all? Today I removed the rear plastic inside the boot of my tourer and disconnected the pipes from the nozzle and operated the washer and I'm getting nothing at all so Its not a issue with the nozzle being blocked. From the drivers seat I can clearly hear the motor operating. I removed the wheel arch trim and operated again and I cant see any visible signs of the fluid leaking anywhere in the engine bay or on the floor?
I'm wondering if perhaps the pump is blocked or failing and doesn't build up enough pressure to push the fluid to the rear of the car, is this a likely scenario? Also does any one know what route the pipe take from the engine bay to the boot, I'm ***uming its through the roof lining?
I've lost quite a lot of pressure in the front jets also, I ***ume that they both have separate pumps or do they operate of the same pump?
Any advice would be gratefully appreciated.
Cheers Dan
Cheers Dan
